Menvier Fire Alarm | on ElectriciansForums
Discuss Menvier Fire Alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
sparkyste1
Hi All,
Have an old menvier fire alarm which has a detector fault. I know I can't buy a new head now as thy are obsolete. Means I need to install a replacement head and base.
Question is, do I have to replace this with the new/current replacement that menvier offer or can I install a different make
Thanks in advance
You could use either menviers new 5 in 1 detector or Apollo 65 detector, you will need to split the negative terminals on both of these to allow fault removal to work properly
Apollo S65 detectors do not have a polarity, and will work on Menvier by using L1 in & out on the negative side in reverse, or by turning diode around. So L2 is wired positive and L1 in out is wired negative.
Thanks, What wholesaler do you use to purchase your Apollo materials from. Job is over an hours drive each way and just found out I am there in morning. Be useful to know where the nearest stockist are in if needed.
Reply to Menvier Fire Alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Have you checked the RJ 45 type lead that connects the pcb to the power supply in behind is properly connected? What voltages do you get at the...
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
