merlin gerin mcb and fault indicator switch | on ElectriciansForums
Discuss merlin gerin mcb and fault indicator switch in the Australia area at ElectriciansForums.net
A
ach69uk
i have a merlin gerin C60 2A MCB and a fault indicator switch in front of me i have tried to put the two together but the indicator switch will not connect to the mcb i know it may seem daft but i thought these things was a plug and play kind of thing i have removed the retangular small plate of the mcb for one of the white pins to be inseterted from the fault switch , but the black pins on the fault switch prevent it from fastening it to the mcb
does anyone know if there are suppose to be removed or not or if i have something missing to this
photos of the fault indication switch and the mcb are on this thread too
  • [ElectriciansForums.net] merlin gerin mcb and fault indicator switch
Reply to merlin gerin mcb and fault indicator switch in the Australia area at ElectriciansForums.net
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
