Sonor
Has anyone had a problem with the covers for these boards?
I've fitted a Merlin and the cover apertures, where the circuit breakers come through are about 2mm out. I had to put the cover on as the board was replacing a smaller board in a busy Restaurant.
But then, when fitting a Square D board the same thing!
DSCF0041 on Flickr - Photo Sharing!
As you can see there is a gap and the cover is resting on the breakers on the both sides.
The Boards are Square D KQII and Merlin Gerin Isobar 4, which to all intents and purposes are the same board, but painted a different colour.
I will be contacting my wholesaler to see what gives.
