Metabo Wall Chaser MFE 40 | on ElectriciansForums
Discuss Metabo Wall Chaser MFE 40 in the Electrical Tools and Products area at ElectriciansForums.net
Same as Risteard.
I’ve had mine 2 years next week, can’t fault it at all, the best blades I find are the turbo blades. They cut anything and last far longer than a diamond tipped blade.
The vacuum is the important bit now lol
I've used a Metabo, not sure which one. Excellent piece of kit, not withstanding its quite heavy, and you need to be careful when using it.
Agree about the associated vacuum, definitely a requirement.
The metabo blades wore down from almost new to thin and short in 2.5 tracks in an ex housing executive house built in the late 60’s, the blades started to glow red lol
No, they’re ordinary ones, looking at these, are they designed to save chipping out?
Looks almost like it’s grinding the entire chase out, like those things that strip up the tarmac.
Just watched a YouTube video of them, some job alright.
Wonder if they’d work in a MFE30 lol
I still don't know if they really work in an MFE 40. A rip saw with a blunt wood blade would cut through thermalite block after all. If they do work and last long enough I'd replace my chaser and if required my dust extractor for it.
Reply to Metabo Wall Chaser MFE 40 in the Electrical Tools and Products area at ElectriciansForums.net
I do very little chasing, but managed to destroy two cheap chasers, one of which was Parkside. The motor simply couldn't cope with the force...
nicebutdim
N
In UK, they’re all wall mounted… or pole mounted… fixed down, anyway. Except, I believe the roadside recovery companies have charge points on...
