Metal clad db. | on ElectriciansForums
Discuss Metal clad db. in the UK Electrical Forum area at ElectriciansForums.net
Southport
What is the correct way to replace a 3 way storage heater fuse box - a separate DB or incorporated in main DB which is also to be replaced?
Can you provide more information and/or photos of the current set up?
It also depends on the storage heater arrangement, whether it is fed from a separate supplier time-switch, as to what is easiest.
See attached photo - the upper box is the current storage heater fuse box fed from supplier time switch.
  • [ElectriciansForums.net] Metal clad db.
Reply to Metal clad db. in the UK Electrical Forum area at ElectriciansForums.net
Obviously you need to check the means of earthing, Ze, and polarity no matter what for the EIC. As above, if anything looks dodgy then EICR is a...
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
