Metal conduit | on ElectriciansForums
Discuss Metal conduit in the UK Electrical Forum area at ElectriciansForums.net
Newcastle
Does metal conduit need earthing , and if so what size ?
I’ve pulled twin and earth double insulated cable through old metal pipes, previously used for singles, the circuit is on a RCD.
As the conduit is not the sole means of earthing the circuit, the cpc in the cable is… all you need is to ensure the metal back box is earthed, which in turn is connected to the conduit.
If the conduit is continuous, then wouldn’t rewiring in singles have been easier to pull in
Reply to Metal conduit in the UK Electrical Forum area at ElectriciansForums.net
In Theory that’s a good argument but if you will be adding or moving switches or sockets or adding lights you’ll more than likely end up needing a...
Ask the architect or better still the ceiling installation company they may point you towards the manufacturers of the ceiling frame and or...
