Metal Consumer unit with SWA bottom entry | Page 2 | on ElectriciansForums
Discuss Metal Consumer unit with SWA bottom entry in the UK Electrical Forum area at ElectriciansForums.net
Dorset
Got a job to replace an old metal Wylex CU (domestic). SWA is embedded in the wall except the last 300mm (or so) and then comes out and enters CU via a gland.
Obviously looking at a metal replacement and have been looking at the new Hager options but these don't look like they'll take a bottom entry SWA very easily. Busbar seems very close to bottom of CU. Swa is 25mm, so not that easily bend to avoid, and there isn't the usual space next to the incomer switch as found on the plastic versions.
Any suggestions?
I think you need to pull some more of the SWA out of the wall. A bit of boxing-in afterwards perhaps? Sounds a bit of a struggle. Though I quite like Ryans suggestion. Good luck with it!
Good grief some people really do like to make a mountain out of a molehill!
The OP wants suggestions for a board with a bit more room between the busbar and the bottom of the enclosure and this somehow turns in to a job of chasing cables in, adding switchfuses.........
the schneider isobar type A have a lot of space in the bottom
[ElectriciansForums.net] Metal Consumer unit with SWA bottom entry
I don't want to even try and get a price of one of those, expecially full of RCBOs
toolstation sell schneider boards for ÂŁ16.50.
schneider rcbo's are ÂŁ20 on toolstation
ill be honest we used them because we got them very cheap, cost us less than if we used bg,click or legrand etc.
hager boards have a good anount of space in the bottom
Reply to Metal Consumer unit with SWA bottom entry in the UK Electrical Forum area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
