Metal Halide Lamp failure | Page 3 | on ElectriciansForums
Discuss Metal Halide Lamp failure in the UK Electrical Forum area at ElectriciansForums.net
West Yorkshire
Hello
I attended a customers property today to check on a fault with some latern courtyard lamps. There are 4 lamps and the centre 2 are not working. The customer had replaced the bulbs himself but there was no joy.
As a first port of call I swapped the 2 working bulbs from the outer fittings with the unworking bulbs to rule out bulb failure. Once swapped the bulbs are fine with the outer two fittings but still no light on the centre 2.
I used a lightmate on the centre fitting and voltage is present at 230v. The customer was not present in the property at the time so I could only access the yard however there is no sign of any ballast anywhere near the lamp. The lanterns are attached to a high wall (perhaps 20ft) with pillars which the lights sit on. The flex from the fitting simply disappers down inside the pillar. I have done work at his property before and there is a room containing all the consumer units, AV gear and switchgear for the property but I cannot for the life in me remember seeing any ballasts for sodium/halide lamps in there, just armoured cable for the courtyard lighting exiting the room underground.
I didn't have my multimeter with me so the only test I could run was that voltage was present and even to check the fitting was tight used a normal BC energy saver which lit in all fittings.
What should my next course of action be? I'm not going to lie I don't have a huge wealth of experience with arc lighting. The customer had reported that the RCBO supplying the courtyard lighting (C6 RCBO) had tripped a couple of times prior to him changing these 2 bulbs after which there has been no more tripping.
Does this sound like the ballast itself is at fault? I think I already know the answer to this but would you think the original fitter have been stupid enough to encase the ballast within the pillar or even under the driveway for some reason?
The bulbs in question are these http://www.venturelightingeurope.com/products/whitelux-plus-lamps/13742.html which appear to be a direct swap for HPS lamps using the original ballast
Why don't you just admit you do not know what you are doing and get an electrician in to do the work.
Why whenever anyone asks for advice about a topic which they may be less than expert is the standard response from some people to flame and try and put the poster down? Surely the whole purpose of this forum is to share knowledge?
That's bit harsh dude.
The OP is simply trying to make sense of a setup someone else has installed. Who knows what the installing spark has done.
What would you do in this situation then? I'd love to know 'cos apart from a few things I know about lighting through my day job, I think I'd be head scratching too.
Care to share the few things you learnt from your day job? :grin:
If you have read any of my posts, they are all things I have learned from my day job. I don't get paid to post here dude, so I'm not sure what you mean by this.
I'm going to withdraw from this thread now because I feel my input has been exceeded and as the dragons would say, 'I'm out'.
Be great to hear if this gets resolved, but I'm not holding my breath.
Nighty
x
Reply to Metal Halide Lamp failure in the UK Electrical Forum area at ElectriciansForums.net
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
Recommended Sponsor News
Hi everyone,
