A client has a metal splash back on the wall along the length of the worktop in a kitchenette.
There are several sockets mounted flush in the splash back, the circuit is covered by a 30ma RCBO as you would expect.
Does it require bonding as being as there are sockets mounted in/on it as there is a potential to introduce a fault?
It isn't an extraneous conductive part so no need to bond it. As spin says earthing it might be required.
I'm about to fit a stainless splashback for a kitchen install I'm doing.
Never even thought about bonding it to be honest, should I?
if the socket faces are metallic, then the splashback would automatically be earthed.
west brom
Metal splashback in kitchen.
silver surfer,
telectrix,
