Meter exchange - CT | on ElectriciansForums
Discuss Meter exchange - CT in the Talk Electrician area at ElectriciansForums.net
gazdkw82
leicester
I have an ND CUBE 400 meter to exchange next week. Its a like for like change. I can isolate the supply to the meter easily with the removable cartridge fuses, however the circuit the meter is metering cannot be isolated. I am not sure what risk is posed with the CT's. They are terminated into a terminal block so i can just pull that block out and insert into the new meter, i just thought i would check i as am unsure if this is the standard with CT's
Depends on the CT type as some (iron core) can produce very high voltages at open circuit, there should be a shorting block installed to allow for shorting the CTs secondary before removing the connections. Best check the CT type first before pulling it.
Reply to Meter exchange - CT in the Talk Electrician area at ElectriciansForums.net
It sounds like the company involved in the works doesn't have the necessary expertise to undertake the task A company that specialises in this...
Thanks guys, that was my alternative thought, as I am running a cat 5 cable for Internet so it has crossed my mind to run another one for the CT...
yeah so it looks like an old off peak heating circuit to what would have been storage heaters my preference is to remove them completely from the...
I hope this is not a trend by our energy companies....... a 200KVA supply is pretty standard for larger commercial . Are you sure you are talking...
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
