Meter obstructions | Page 2 | on ElectriciansForums
Discuss Meter obstructions in the UK Electrical Forum area at ElectriciansForums.net
T
The_Body
Hi guys,
A friend has just bought a house an the electrics haven't been touched since the 60s when it was built.
Still on fuse wire bacolite fuse carrier etc...
So the problem is the Gas meter is infront of the main fuse and fuse board. The gas meter blocks clear access to the fuses.
This makes putting a new consumer unit in pretty tricky.
Gas board have said its not their problem. An it will be £600+ to have them move it out of the way ( approx 600mm).
Any thoughts?
Reply to Meter obstructions in the UK Electrical Forum area at ElectriciansForums.net
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
