View the thread, titled "meter problem" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
B
brucegenerator
Wired up a pv system over Christmas but meter is not ticking over.When connecting generation meter should inverter tails go into incoming side of meter as i have wired mains tails into incoming side.Will this correct the problem?Seems to work fine otherwise.Cheers.
Was told the meter wound forward and back depending on usage and could get no technical info as supplier was on holiday.Anyway know now thanks all.
Reply to the thread, titled "meter problem" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
