Meter reading corrupted | Page 4 | on ElectriciansForums
Discuss Meter reading corrupted in the UK Electrical Forum area at ElectriciansForums.net
Karen W
West Lothian
Hi looking for a bit of advice about an issue I have with some work arranged by a social landlord. The landlord had to fit a new consumer unit but sent out a contractor to fit an isolator switch the week before. He also renewed all the wiring from the mains fuse and the meter tails. When the new consumer unit was being fitted I got an email from my power company asking for meter readings. At this point I noticed a discrepancy in my meter reading of around 40,000 kw/hr. It’s one of the old style meters in the black case with the numbers that turn round.
The contractor originally denied having moved or changed the meter in any way however now admits moving it as I provided photographs which proved he did. The contractor and my landlord are both saying nothing could have happened to my meter during the works carried out. My power company intend to bill me as I have evidence of how the meter reading became corrupted during the work.
Can anyone here shed any light on what might have happened?
I'd be reluctant to let the meter be removed unless it was going to an independant meter test / calibration company.
Once the supplier has the meter and it's been thrown around in vans along the way, you've lost any evidence that the meter may be faulty.
The power company is now sending someone out to inspect the meter. I have kept all the photographs and emails as evidence too.
They said if the meter is found to be faulty they will replace it and bill me accordingly. Maybe I shouldn’t let them remove it until this is all sorted then.
I may be a bit old and stupid but I am sure 77001 - 17296 = 59705? i.e. 60k difference! Thus your meter moved back 60K by what appears to be the first digit slipping. I would be asking for a refund on the basis of the energy companys inability to see that it has gone back, and saying forward hence charging you for the extra. Incompetent hardly describes it.
Computer also says that if it's gone forwards, then you must have used the electricity.
That's the way things work with big, faceless companies. The default is that they are right and you are wrong, so they leave it to you to protest, and then protest again and again, and eventually someone will actually listen.
Don't take it personally, don't pay, and don't worry about it. Eventually they'll see sense, and you will normally get a little ex gratia payment for your trouble.
Reply to Meter reading corrupted in the UK Electrical Forum area at ElectriciansForums.net
Thank you to littlespark for clarifying my mumbo jumbo. Just to say that being on a dual tariff means you will typically pay more for electricity...
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
