Meter tails in cavity | Page 3 | on ElectriciansForums
Guest viewing is limited
Discuss Meter tails in cavity in the UK Electrical Forum area at ElectriciansForums.net
mattg4321
V.Nearly Esteemed
South East UK
Ok own up who's done this?
I try my hardest to never do this but have, on very rare occasion installed meter tails in a cavity as the lesser of evils.
Would be interesting to hear real world thoughts on this and potential work arounds so you don't have to. I know someone on here posted a while back about some sort of capping that you could put over the tails so they couldn't be drilled. Not entirely convinced about that although I've not had a proper look at it in real life.
I had one recently where the meter box was on external wall and I needed to run an armoured from there to an internal consumer unit. Went to great trouble to avoid running the cable in the cavity and builder comes along and says why didn't you just push it up the cavity!
Just out of curiosity, what do you guys do then you put cable in the oval trunking like below?
What max length do you use.
As you see by my earlier post. There is no actual length specified in the regs.
Hi - well, it's just used for drops from ceiling, so typically less than 3m, and there never seems to be any issues.
Just for some fun (still sick today:( ) - I did see some data saying soft copper could take a static load 15N /mm2 without damage (internet source, so not sure if correct). Now 1mm twin and earth would be 3mm2, so about 4.5kg max static load. But for safety, let's assume only 1 core takes all the load and for further safety divide my internet number by 2, that's about 750gm loading, not much! But I get 1m of Prymesian's finest 1mm twin and earth to weigh in at 60gm, so 3m of it seems fine for hanging undisturbed in the conduit. Hopefully :) .
Reply to Meter tails in cavity in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
Recommended Sponsor News
Hi everyone,
mattg4321
V.Nearly Esteemed
South East UK
United Kingdom
