Meter Tails in Galvanised Trunking...Is that a thing? | Page 2 | on ElectriciansForums
Discuss Meter Tails in Galvanised Trunking...Is that a thing? in the UK Electrical Forum area at ElectriciansForums.net
London
Hey all,
Excuse the ignorance here but I wonder if you lovely folk might have any opinions or better still be able to point in the right direction in the BBB.
I am being asked to move a CU from its current position, behind a fitted kitchen, under the sink and totally inaccessible, except to the countless bottles of Fairy and Pledge etc, that share a home with it.
The meter backs on to it in a recessed box. I need to move the CU all the way down the side of the house, about 8-10m and pop it back on the same wall. I was going to pop an IP65 metal enclosure in the current location and extend all the circuits (actually only 4, thank goodness (or words to that effect!!)) along the outside of the house in singles inside galvy steel trunking. The house has a concrete floor throughout so there's no popping up a board here and there and running the lot along the dirt.
So far, so simple...SO...moving on to the incoming supply side...The meter will now be about 8-10m away from the proposed site for the CU. I normally install a fused switch and then run the appropriate sized armoured (in this case it'll be 25mm) from the FS to the CU. In this instance I was toying with the idea of not doing that but to run meter tails inside the galvy alongside the extended final circuits. Is this acceptable? If not, can you point me in the direct of evidence to this end in the BBB. I have a niggling concern that the DNO only want SWA used to feed CUs or DBs when they're over 3m from the incomers, but for the life of me, I don't know where I go the info...I may even have dreamed it.
Thanks in advance for all your help with this quandry, and obviously thanks too to Pete, who will no doubt point out the fact that I should, in fact, have become a cab driver and left this electricing lark to my betters!! ;-)
i've moved meters on a few jobs like this. great big board and the meter stuck right in the middle. (disclaimer. it wasn't me, nobody saw me do it, and you can't prove it (fingerprints wiped and no DNA left at scene)).
They've got CCTV in the meters now so unfortunately you've been collared!
Hey all,
You'll be installing a switch fuse as the new CU is >3m from the meter therefore only the tails from meter to switch fuse need to be 25mm. From the switch fuse to new CU the 'tails' need to be sized according to the size of the fuse in the switch fuse, so probably 16mm.
The DNO will give you a maximum length for tails. (usually 3m). You described the best way earlier which is to run them into a fused iso and then run off SWA it singles if protected correctly. Neither need RCD protection so won’t be a problem.
Reply to Meter Tails in Galvanised Trunking...Is that a thing? in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
Yeh that’s my thinking. I have to supply the box so can order a bigger 3 phase option to give myself a bit more room
