Meter Tails | Page 2 | on ElectriciansForums
Discuss Meter Tails in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Wots a floating gland, I have an idea, and seen it prompted on this forum, but just to be clear.
It is where the cable is glanded off in a cavity and not to an enclosure, not something many people and myself approve of but it is common practice.
What is the point of a 'floating gland'? It doesn't fulfill the purpose of fitting a gland to the end of the cable.
Why not use a different method of terminating the SWA which does actually serve the purpose instead of bodgeing it?
[QUOTE="Nightmare1308, consumer unit is other side of the door and there is no safe zone to run the cable
Whispering mode cavity,tails ;) :)
It's got a floating Gland which is fixed into place by cable cliets. :(
It also has a layer of heat shrink. Which then the cable connections go straight into the DP isolator. :(
It hasn't got any SF because it will not fit in the meter box with the REC equipment :(
[/QUOTE]
Bit glum with this post
Had the same feeling when i see it installed by the team.
But it has been glanded and banjo has also taken down to the met. The SWA gland and banjo has been covered with waterproof rubber taping to protect it from water ingress if ever possible.
The Rec double pole switch is within a REC meter cupboard but trying to understand the risk of the SWA core being damaged or we just frowning apon this?
The fact it is a earthed metallic covering (SWA) does it require a safe zone and it's most likely going to be 50mm deep after the dot and dab is lined up with the stud wall.
The idea with tails in a cavity, has been pulled via the NICEIC before that's why we avoid that route as the single cables can be hit if not protected, e.g cavity wall insulation drillers.
we can only work with what we got currently but looking to see if any regulations are broken ? I
no that it don't make any of this better and it's not my work, I'm just trying to settle the debate of who's right and who's wrong with regulations.
Moving forward with we trying to come to a solution of what to do but struggling with client as neither of my solutions are liked that's why this all started.
Just to clear the floating gland up, (Short and long of it) manufacturers instructions on some telecoms kit is specified to be done that way. As much as I didn't like it originally NIC couldn't advise otherwise. But we all do different line of works within the electrical industry
I would consider the heat shrink not giving conductors adequate mechanical protection. The fact you could never fit the heat shrink up into the cable sufficiently would render the conductors as not being suitably enclosed. It is a poor method to solve a problem and I always comment on an EICR if I see such a situation.
I must be interpreting the regulations differently as I thought the meterbox was an enclosure (equipment surround by a barrier). Where is the risk of mechanical damage to the cable if the meter box was in a sound condition ?
Just trying to understand your point of view.
Is there any regulations out there for the main topic?
A meter box as a suitable enclosure for a cable joint (like a giant junction box), if I've understood correctly?
Plenty I see have broken doors and since householder commonly approaches the meter anyway (to take a reading) I don't think the box can be relied upon as a barrier. But that's just my thought.
Yes but on a condition report you would only report on the safety of the meter box at time of test, we can't retrospectively apply regs.
I'm still trying to work a way round for the lads on this issue, I don't disagree with the SF idea but it's not going to fit next to the REC and even if I removed there double pole isolator (which I can as I'm MOCOPA approved) what can I fit in the meter box.
What would you do "Wilko" with what they got?
As it's a 25mm 3 core SWA coming though the top knock out (with fire resistant foam to seal the cavity when it's done).
My biggest struggle is with the designer as he saying find me regs showing he's wrong.
Thanks for your replies.
Reply to Meter Tails in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
