Metering electricity usage | on ElectriciansForums
Discuss Metering electricity usage in the UK Electrical Forum area at ElectriciansForums.net
Scotland
Good afternoon,
I hope I am asking this in the correct place and apologies if not.
Firstly I am not a sparky but I have a question that will be straight forward for you guys on here.
I am going to be renting a small premises and the feed for my unit is coming from a 415v distribution in the adjoining unit. The feed will run to a board for my own use, it will just be 2 loops of sockets, 2 of lighting and a hot water cylinder. Or something along those lines.
The owner will bill me for electricity used - is it simply a case of having a 100ah meter (or something else) installed between the distribution board and my board? As I've mentioned I'm not a sparky myself but I would like to know the easiest way of setting up a metering system.
Thanks in advance.
Reply to Metering electricity usage in the UK Electrical Forum area at ElectriciansForums.net
This was posted this week, on topic ....... https://niceic.com/newsletter/omission-of-overload-protection/?dm_i=7G1W,7GCE,K4L2A,WHET,1
if the 3 spaces with charge points are always allocated to the same 3 flats, surely the easiest way is to run the supply to the load side of the...
