danny124
Hi guys got a assessment coming up this monday. Got a new meter as above, but didnt come with Fused test leads, i practiced without these, and know how to use the instrument well....
I purchased the fused test leads on monday, and have done 2 Ze tests on 2 differant properties with my boss, and each time the fuse blows in the Line probe.
Im doing a Ze test as per instructions in manual, select Loop L-E, discon main earth croc clip to earth, N probe then Line Probe, press start and and get rcd message..... go to do it again, says no voltage...
I then test my fuses out the probes and the line probe fuse has blown....
I just read on here on another thread that my tester can aslo do Ze by linking up E-N probes together and clip it to earth, and put probe on line..... Well done this and got the same outcome.....
Has anyone else had this problem, i get the feeling im screwed for monday now!!!!
Cheers guys
Cheers guys
