C
colface
Metrel MI3000 Easi Plus, Can you do a ring circuit continity R1 + R2 test at the socket outlet with this tester? Or do you need to purchase a R2 socket adaptor?
I think you would need a socket adapter, resistance on my Metrel MI3002 is only measured between the brown and blue leads so using the plug adapter you would not be able to measure line to cpc, only line to neutral.
Metrel MI3000 Easi Plus MFT
colface,
colface,
