Metrel Mi3101 I/R Reading | on ElectriciansForums
Discuss Metrel Mi3101 I/R Reading in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
silverback
Hi Guys,
Please syop now - answer found. Cheers
I hope someone may be able to clear up an issue with my Metrel Mi3101 tester.
Doing an I/R test on the single test setting I have been getting on numerous but not all of course a reading of >30Mohms which my boss has queried - not having used or seen my new multitester. He is concerned that this is an unusual read out and wanted to make sure it was all ok.
I have read through the manual but can't find a specific mention of it.
Other readings have been figure amounts that have nit been questioned.
Regards Callum.
Reply to Metrel Mi3101 I/R Reading in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I don't think it will work with only one stake unless some meters have different operating parameters. It doesn't necessarily have to be a stake...
I'd speak to an independant company about fixing this, you'd expect it to be a relatively simple adjustment and not require much in the way of...
davesparks
