If the loan MFT,is a Megger......you might not give it back...
Discuss Metrel UK ........... 5 star service in the Electrical Tools and Products area at ElectriciansForums.net
To be fair 9 years is pretty good for an entry level budget tester.
I would guess occasional light use is the reason it survived so long.
That will be because it's not a Fluke or Megger instrument then
Having used a Metrel MFT for 15+ years I don't think they are entry level and certainly not budget level
My Metrel MFT certainly has had well more than occasional use. If I was looking for another MFT it would be bought on the MFT's merits not just the name and Metrel would certainly be in the frame as for me it has a proven track record
It is nice to have a positive thread.... however ..... I have had both a metrel and a megger. I thought the metrel was fine whilst I had it but now I have the megger I would not go back to the metrel. I feel the results the megger give are more reliable. As an example, the metrel always gave different readings on continuity just for the test leads (when nulling), this really put me off. The megger always gives exactly the same reading (i.e 0.06ohms).
Also, you could test the same cable twice and get fairly different continuity readings (this was with a calibrated metrel), whereas with the megger this does not happen.
However, the service that Metrel have given Murdoch sounds very good.
Reply to Metrel UK ........... 5 star service in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
