Micc conversion from imperial to metric | on ElectriciansForums
Discuss Micc conversion from imperial to metric in the UK Electrical Forum area at ElectriciansForums.net
Evening Gents,
Does anyone has conversion chart for MICC cables Imperial to metric , I have to admit I am not an authority when it comes to MICC.
Sparky 63
I haven't used a conversion chart however I have used the table on page 10 of this catalogue:
http://www.fire-cables.co.uk/documents/Pyro Catalogue.pdf
Measure the outside diameter of the imperial mineral with some calipers (they need to be accurate to within a tenth of a millimeter) and then size the appropriate pots and glands from there.
We have found we can`t match metric with imperial.....so have used the nearest imperial gland to terminated in adaptable box, crimped and continued in metric....is there a better solution...??
certain metric glands will fit imperial micc a digital vernier is what you need, the pots can be a problem to fit correctly but as a last resort you could drill the pot thread out and solder them on
Or look for the 3-digit number on an existing gland to confirm the replacement gland size. If you know that and the number of cores it completely identifies the original cable. E.g. a 2-core cable in a 234 gland would be 0.0015 sq ins or 1mm²
8mm OD on a lighting circuit? 8mm is 0.315in., for a 440V 2-core that would be closest to 0.0045 sq ins which is about 2.9mm², which is 0.324in OD. For a 660V it would be closest to 0.002 or 1.3mm² which is 0.340in OD, but would not expect a 660V cable on a lighting cct.
Check that number...
Reply to Micc conversion from imperial to metric in the UK Electrical Forum area at ElectriciansForums.net
B
Milwaukee Press Jaws Imperial vs. Metric I’m moving from USA to the UK and with my tools is my Milwaukee ProPress gun. I am under the assumption...
bundle45
B
Thanks for that guys I was more thinking about difference in potential between the tub and wet paving flags . The tub is plastic . But it’s the...
