Micc | Page 3 | on ElectriciansForums
Discuss Micc in the Australia area at ElectriciansForums.net
the pict
Mentor
Brodick
Today I undone a tangled mess of cables in a enclosure it contained lighting and heating and alarm cables none with any id, after about 3 hours I had the whole lot sorted and reconnected, apart from one MICC which had the conductors exposed taped and silicon sealed as a insulation method, no really, as this had only one N connected to a live feed, and I assumed it must be a unused circuit, that is untill the publican tried to switch on a couple of florries which failed to work. After going through all I had done, I thought, surely not, but yes this was the supply to said florries, so now I need about 20 metres of 1.5 But why was this used, in the area served it is all done neatly into domed shaped flex outlets, with the MICC all glaned off proper, was this a normal practice it is in a large glasshouse used for fucntions installed in the 50's
Pict
PS anyone got a pictorial how to for MICC
If I ever need to repair any of this type of install I will post the job on here, tbh I couldn't be arsed with it ,I suppose on a new install it'd be fine but repairing this stuff after 60 years in service I think the moisture would be pouring out the far end.
Pict
Not if the pots were made off correctly, no way!! MICC can out live yours and my life times combined, ....and then still keep going!!
Reply to Micc in the Australia area at ElectriciansForums.net
