Micro Pumping Station RCD? | on ElectriciansForums
Discuss Micro Pumping Station RCD? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
its
Hello,
I've got to get power to a Flygt Micro 5G pumpng station. (1.1kw) so I'm going to run 1.5mm SWA out to it on a dedicated circuit. Do I need to RCD protect it?
Depends on the Utility companies specification, generally the pump should be controlled via contactors (overloads etc) within an MCC. RTU's (Remote Telemetry Unit's) then monitor the MCC to report via SCADA to a Master-station site.
Reply to Micro Pumping Station RCD? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Bugger that. They end up in whatever position they want :D
    • Informative
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
