Currently reading:
Microswitch in lighting controlled by rocker switch issue
Discuss Microswitch in lighting controlled by rocker switch issue in the Auto Electrician Forum area at ElectriciansForums.net
Hi and thankyou for reading this. I have an issue where my lights in my camper (12v LED) contain their own switch which is reset every time i use the rocker switch to turn them off. This means that i have to turn on the rocker switch and then turn on the microswitch in the lights - which is a pain! If i leave the rocker on and remove the fuse from the fuse board, then the light functions as expected by reinserting the fuse and the light remains on. I expect that there is a residual low current in the circuit from the fuse board led warning lights. How can i replicate this in the rocker switch? or is there a rocker switch on the market that will provide a very low current in the off position?
I'm familiar with 12 volt lighting circuits in caravans, but I'm afraid I have no idea what you're talking about, and I suspect I'm far from the only one.
You'll have to explain further.
This can be achieved by connecting a resistor across the switch terminals.
Thought it was just me :)
Reply to Microswitch in lighting controlled by rocker switch issue in the Auto Electrician Forum area at ElectriciansForums.net
