Derek Reay
Hello,
I have been working on a Central heating system where , after selecting the heating to come on, it often trips the Circuit Breaker. Throughout the Summer, it appears that there were not any problems, when only the Hot Water was selected on the Timer programmer.
Both the valve and the Pump are situated in the loft as the property is a Bungalow. Having looked at the Mid position valve it seems that this had been a replacement for a 6 wire valve. I say this because there was a 'Switchmaster' controller , with cut off wires, next to the BGMVSP 23 valve. There was also another empty box next to that, but the label had faded.
Having looked quickly at the junction box, there is a 6 wired cable coming out, which is connected to a small 2 part, 5 terminal cable connector block. That part of the block has both a Red wire and also an Orange wire connected together in the same terminal. However, the cable from the actual valve is only a 5 wire cable. and each of these wires is connected to its own, individual terminal in that part of the connector block.
I am assuming that these different wires are causing the tripping of the Circuit Breaker, once the Heating is turned on.
Can anyone advise on this strange set up please. Or should I study all of the wires in the Junction box, and re-wire the valve into the box with just its own 5 wire Cable?
Many thanks,
Many thanks,
