I’m looking to sell my Milwaukee Kit. It contains:
1x 18v SDS
1x 18v Combi Drill
2x 5.0ah Batteries
1x Charger
1x Carry Case
Collection is from Liverpool. I’m looking at £280 Ono.
1 x 18 Volt M18 BPD Compact Percussion Drill is a compact, high performance percussion drill that measures only 198mm in length, making it ideal for confined spaces. Its high performance 4 pole motor delivers maximum power whilst maintaining the power to weight ratio. It has a full metal gear box delivering maximum performance and long life, with a 13mm metal chuck for quick bit changes and bit retention. Chuck: 13mm. No Load Speed: 0-450/0-1,800/min.Impacts Per Min: 28,800/min.Max Torque: 60Nm.Capacity: Wood: 38mm, Steel: 13mm, Masonry: 16mm.Weight: 2.1kg. 1 x 18 Volt M18 HD18 HX SDS Plus Hammer Drill offers 3-modes of operation and a FIXTEC keyless chuck changing system. With AVS for comfort and REDLINK™ overload protection for excellent durability. Modes: Rotary Hammer, Hammer Only, Rotation Only.No Load Speed: 0-1,400/min.Impact Rate: 4,200/min, 2.4 Joules.Capacity: Wood: 30mm. Steel: 13mm. Concrete: 24mm.Weight: 3.7kg. 1 x 12-18 Volt M12-18 FC Multi-Voltage Li-Ion Charger recharges all M18™, M14™ and M12™ REDLITHIUM-ION™ battery packs. It recharges in sequence first in, first to charge - resulting in less time needed to manage charging cycles.
1x 18v SDS
1x 18v Combi Drill
2x 5.0ah Batteries
1x Charger
1x Carry Case
