W
wattsup
Just having a pint in the local, finished early about 2pm...landlord is having new glass washer fixed. 30a supply, double pole switch under sink...anyhow the guy gets finished and goes. Landlord says just have a look at this please it don't look right...switch swivels like a catherine wheel, one screw and thats not tight. Incoming supply 6mm t&e is a tangled web, all located beneath a leaky sink, fed from rewirable fuse in cellar
Anyhow he says is that ok?
Err nope not really.
Why?
I would have used an rcd and tidied the mains in, and located in cupboard adjacent sink.
To be perfectly honest not sure if the rcd is totally needed (cant spell neccarsary) but I would not have fitted without, my feeling is, if unsure err on the safer side, that's by the by.
So then the onus is on me, when he says, 'is it safe, can staff use ..
I'm thinking **** me I only called for pint, err, I'm not going to say its safe and i'm not going to say it is unsafe, but it doesn't look ok to me as a visual inspection, I'm not going to disconect and check connections etc... or I will be the fall guy if all goes ape****, all i will say it should not have been left like that.
I asked what he actually paid for, he said supply and fix of glass washer, 2 grand (it was a replacement unit, exisiting supply used etc) So I guess the former glass washer was potentionally just as bad
Oh! err nope it is not safe to present day standards, nor is it safe to 10 years ago standards
Ok he says how much to do it properly
I don't know off the top of my head, but it will more than ÂŁ100 perhaps ÂŁ150/ÂŁ180...maybe more if you want 32a plug on the washer and rcd socket..
Oh no he says, I'm on the phone to them, I'm gonna stop the check I just paid, unless they come back and sort it...friggin hell it always happens to me.
I can imagine the company concerned ...a pesky local bar-room electrician know-it-all...
What did he expect me to say? yeah thats ok, no problem..
Why?
