K
Krispy
My house, built in 1960, has mineral insulated cabling and a voltage operated earth leakage circuit breaker. We moved in 7 years ago (don't suppose that is relevant though )
Due to some rebuilding work the meter needs to be moved, and in preparation for that my electrician has fitted a new distribution board; the supply connection, once changed, will become TNCS/PME.
In readiness for that he today tested the existing circuits and found that the insulation resistance showed as being very low - zero on some circuits, 100K-400K on others, and I believe that 1M is required?
He fitted a current operated RCB as an experiment to see what would happen - it tripped immediately.
Meter is due to be moved next Thursday. Whole house rewire wasn't in the plans ... in particular not doing it next week
My electrician (after a phone call to his affiliated membership organisation) says that we could fit RCBs on the lighting circuits in bathrooms and leave the rest of the lighting circuit unprotected, and could fit RCBs adjacent to, or within the socket, on all power sockets. I figure that would probably look a mess and it would be better to consider rewiring, but that's not going to happen overnight.
I'd appreciate any suggestions / advice you may have. Thanks.
