Minimum distance for an FSU from a hob. | on ElectriciansForums
Discuss Minimum distance for an FSU from a hob. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Is there any difference in minimum distance for an fsu from a hob than a
Socket. I know it's 300mm for sockets but can't find if its different for FSU's. thanks a lot.
That is guidance only
You need to consider the trailing flexes and whether there is risk of it getting fried for a socket
A fcu may have no trailing flex and if not affected directly by any heat, a closer distance may be acceptable to yourself
Reply to Minimum distance for an FSU from a hob. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
See there is the problem. I can put back to way it was. Is it safe, in my opinion NO!! It's wasn't safe before the incident. No Fused Spur...
N
He hasn't provided any certificates, including previous work. He sends invoices when he needs paying.but no vat registration number etc on...
  • Nessab16
  • Ireland
  • 8
  • 625
Nessab16
N
