OP stated 6 DOUBLE sockets. That's a total of 12 outlets.
I don't know if "cooker switch etc" means more sockets below worktop through a DP switch, but possibly a socket on the cooker switch.
You have put disagree, Murdoch,I did say think please state why you disagree as I could change my thought and be corrected.
A "point" for me is a single socket, a double socket, a fused spur, a light switch, a light fitting....
Do you count all the lamp bulbs in a big fitting or just the fitting?
So in summary, a "point" is where the circuit connects to an accessory ...
Hope this makes sense
I think when it says 6 sockets you count as each socket outlet so a single socket would be one outlet and a double two outlets, therefore, six outlets could be three double sockets.
Not according to the OSG. It says 'Minimum number of twin socket-outlets', and has 6 for up to 12 square metres. So I make that 12 socket-outlets in total, even for a tiny kitchen. This particular section is only about socket-outlets, so any additional switches for appliances aren't included.
The socket on the cooker switch is mentioned in note 1, and isn't included.
It's a good point about appliance sockets but I suspect they wouldn't be included. I think the reasoning behind it is sound, ie. reducing the chance of trailing cables, extension leads etc. and I don't think we could expect people to use an appliance socket in a normal way. I suppose the key point is in note 1, which says that the sockets above the work surface should have no more than 1m between them.
Just talk it through with your spark............
And the OSG nor BS7671 have any ruling on such numbers...
Thanks for replying Murdoch (I prefer people to indicate/point out their view/take than just the dislike/disagree button as they may have a perfectly valid perspective.) In this case, I take the " point" as you have described above.
Maybe the IET should get me to "proof" read their documents ..... and make them less ambigious ...................
Berkshire
Minimum number of sockets?
Thread Tags
WiringPeter,
Octopus,
