Minor works cert question | Page 2 | on ElectriciansForums
Discuss Minor works cert question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
its NOT like for like replacement personaly id do a MWC for it and show the timings for RCD test even if only for the records SOME clients may want a MWC for EVERY job required or NOT
I would fit it and test the socket.
However i would ask the customer if they want a mwc, (explain it isn't necessary) if not don't test the circuit.
You have fulfilled your duty. Ideally record your results.
No need for notification even if it's in a special location, as it's a replacement.
Should have the essential tests conducted, IR, Zs, polarity and RCD.
A MWEIC may be issued, but it's not a requirement to do so.
you issue minorworks you have to notify read up on minor works cause changing a socket plate is classed as diy as is a light fitting
Completely incorrect.
Replacement of electrical accessories where there is no alterations to the cabling is not notifiable , even in special locations or kitchens.
Page 18 , Electricians guide to building regs.
^^^^^^^^^^^^^^^^^^^^ what book was that again!!!!!!!!!!!!
Hi all
My two pennyworth on this is taken from the guidance in the "green book" BS7671( page 394). One needs to read the whole quote, but too long to type out here, but partial quote says "This certificate may also be used for the replacement of accessories and luminaires", but more importantly it says that inspection and testing should always be done irrespective of the extent of the work carried out, and the essential tests are:
Earth continuity satisfactory (tick box)
IR, Zs, Polarity check (tick box), RCD test if applicable.
My opinion is to do the job, test it, issue minor works, then you are squeeky clean to charge a professional fee for a professional job, especially as you are stating that the socket is safe and fit for purpose. (the cert is a permanent record of what you have done and guaranteed)
John
Reply to Minor works cert question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Unless the circuit is new or has recently been tested/certified by a.n.other, I'm not sure how you prove the circuit is 'safe' to connect to...
If this is a genuine change then throw it back at them, a nicely worded email explaining the additional testing requirements and paperwork charge...
