Minor Works Certificate details of wiring system used to modify the circuit ??? | on ElectriciansForums
Discuss Minor Works Certificate details of wiring system used to modify the circuit ??? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
cdm100
Hi on a minor works certificate what is to be put in the box details of wiring system used to modify circuit ? do i put in the description of the reference method ie pvc/pvc or is it something else ? any help would be good.
Flat twin and earth? SWA/XLPE on tray? PVCS in trunking/conduit? Etc., etc? Just a few thoughts, as I don't think there is anything set in stone for this part as I think it's only an NICEIC requirement.
Reply to Minor Works Certificate details of wiring system used to modify the circuit ??? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
On the minor works in the brown book it has Zdb
You can obviously put N/A in some of the boxes like the cable size etc because you haven't used any, you can do a loop test at the thermostat and...
