Minor works certificate | on ElectriciansForums
Discuss Minor works certificate in the UK Electrical Forum area at ElectriciansForums.net
London
Changed 4 way hook up box with individual 16A RCBOs in box,
Part 1 is description of works all good
Part 2 is earthing and bonding yes
Part 3 Circuit details so this is what feeds the box? And the fuse/mcb
Part 4 is test results for circuit altered or extended so these are my results for feed cable and RCD times what have you
Yes again
What's a hook up panel?
I use Hollycroft software certs and they do a
MINOR ELECTRICAL INSTALLATION
MULTIPLE WORKS CERTIFICATE
This gives up to 6 different minor works on 1 certificate, quite handy at times but the results sheet is the same as an EIC so a bit more to fill in.
Reply to Minor works certificate in the UK Electrical Forum area at ElectriciansForums.net
On the minor works in the brown book it has Zdb
If this is a genuine change then throw it back at them, a nicely worded email explaining the additional testing requirements and paperwork charge...
