minor works limitations | Page 2 | on ElectriciansForums
Discuss minor works limitations in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
yes but if you cant isolate the db you cant do the ir test ?
i e very old hrc board or a board with an isolator that wont let you open the cover unless its in off position
Reply to minor works limitations in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Unless the circuit is new or has recently been tested/certified by a.n.other, I'm not sure how you prove the circuit is 'safe' to connect to...
For a new circuit or alteration the dead tests should be done first to ensure it is safe to energise.
