Smart Sparks
Hi all,
Just a sanity check really but all advice welcome.
I went to survey some minor works in a 1 bed maisonette, the works the customer wants consists of light fitting replacement and light switch replacement.
Water and gas are bonded with a green 10mm cable in green, but there is no supplementary bonding or RCD protection.
The cabling is PVC and there are no signs of additions or alterations.
CU is 4,way with 3036 fuses, TN-S
My question is can I just change the fittings on a minor works, without adding RCD protection?. As I am not making the install any worse.
My preference would be to change board to add RCD protection, but not sure he will go for it , based on regs I can't just add supp bonding.
Thanks in advance for any advice you can offer.
