minor works test cert or not? | on ElectriciansForums
Discuss minor works test cert or not? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
Mwoods4757
hi i was at a property and had to change the leg of the ring between two points in the kitchen due to high resistance. i also changed the socket i know this would be maintainence but i always issue a minor works cert anyway to show that it complies.
would this be a minor works cert or an installation cert.
Reply to minor works test cert or not? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
If this is a genuine change then throw it back at them, a nicely worded email explaining the additional testing requirements and paperwork charge...
