K
KEVINDOE
Hello ,
called to fit shower in a housing athourity bungalow, customer says that the previous tennant had one before, there is a circuit in place and has been disconnected on secondary side of isolator.
so ganna come off that if tests ok ,, surley this would be a minor works certificate?? ( all bonding in place}
Im not worried, as its council i need to be right ,, is it not extending an existing circuit ?
You are just extending an existing circuit regardless of whether it is a special location......minor works only required.
Don't you only need new installation if adding to the curcuit re laying cables isnt adding a new installation?
minor works??
KEVINDOE,
james b,
