Minor Works ?? | on ElectriciansForums
Discuss Minor Works ?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
dom23
Hi, I have recently finished a job and am not sure if it requires a minor works certificate. The customer's boiler was removed by his plumber and I changed the programmer and wired for fully pumped system from existing switched fuse. Does this require a minor works certificate? Thanks
It can be a pain but try and issue a certificate whatever you do that way at least if something goes wrong later you are covered for the work you have done. If you havent issued a certificate and something does go wrong people tend to think what else is he hiding.
Chris
Reply to Minor Works ?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If this is a genuine change then throw it back at them, a nicely worded email explaining the additional testing requirements and paperwork charge...
Welcome to Electricians Forums :) Thanks for signing up. :D
