Mira Shower | on ElectriciansForums
Discuss Mira Shower in the UK Electrical Forum area at ElectriciansForums.net
UK
Hi
I have a Mira Digital shower which has been fine.
On Friday night I had to cut the electrics to the whole house and since I put them back on the digital controller has been showing out range.
The Mira "box" is in the attic and have a 3amp fused spur which connects to it. The fuse in that is fine there is also a fuse on the main board that says shower which doesn't trip at all.
I have attached a picture of the board in the Mira box and don't know how I would go about testing.
The odd thing is that even with the fused spur of the board still lights up my electrical pen.
I have changed the batteries in the digital controller but still just get out of range
Board part number 1796.137
  • [ElectriciansForums.net] Mira Shower
First place to start would be the fault finding section of the instructions
it may tell you where to be looking
Hi
I have done all of that. It recommended cutting power, reconnecting the wireless device etc..
None worked. There's a pcb board for 50£ on ebay fully working hence why I want to establish if its the board
There seem to be various instructions online for resetting these showers, don't know if any would apply to your model.
One example: "Turn on electric supply to shower. Within 30 seconds press both the start and flow buttons together. First beep release start button, second beep release flow button. Shower should now be on and leave it alone until it switches itself off (this could take up to 5mins)."
The above is an example only, you'd need to check how to reset your specific model (possibly contact Mira).
Thanks. Yeh tried loads of things. The problem is until I can get the wireless receiver to connect with the mixer there is no way to do anything.
It does seem related that ever since I turnt the electrics of then back on its not been able to connect
Will call Mira tomorrow
I take it you've tried re-pairing the wireless controller with the mixer unit, as you would when installing from new?
  • The Wireless Controller enters “Clock Setting” function automatically when batteries are connected. Press “-” to alter hours and “+” to alter minutes. Press “ ” to set time and exit “Clock Setting” function.
  • Switch on electrical supply to Digital Mixer Valve.
  • Droplet symbol is displayed for approximately 30 seconds. Do not remove the batteries or switch off the Digital Mixer Valve. Droplet symbol goes out indicating Digital Mixer Valve and Wireless Controller have been assigned to each other.
  • Place Wireless Controller in approximate final position (no more than 10 m from Digital Mixer Valve) and test wireless signal by pressing the “ ” and adjusting the temperature. If temperature display remains unchanged and “out of range” symbol is displayed, units are unable to communicate with each other.
Yeh no luck. Will contact Mira today. Thanks
Reply to Mira Shower in the UK Electrical Forum area at ElectriciansForums.net
https://www.electriciansforums.net/threads/mira-shower.194527/#post-1708398 See post #9 🤔 but now I see it didn't seem to work for the OP! Also...
Thanks for the reply, yes the plumber replaced the fuse and it blew again. Replacing the pump, or the PCB is circa £250 each so it looks like the...
