missing earth | Page 2 | on ElectriciansForums
Discuss missing earth in the Australia area at ElectriciansForums.net
J
jparker3007
hi guys
i went to a customers today to do a mains change, it was a tn-s supply, the earth was to a block but there was none to the db:mad:. so while i was changing the db i rectified this with a 16mm. on doing the earth loop test with my megger it was showing voltage between L/E but wouldnt perform test. testing the socket beneath gave me an earth loop of 2.03 ohms??????
im guessing ive got a dodgy earth so what i was going to do was change it into a tn-cs arrangement, have any of you come across this before?
thanks
No lol. Went to price a job 2day for an old lady I said I'd have to up grade the earthing which is quite a job as cu is opp side of rhe house but she said then ooooooo I'll leave that then was just checking I was right I did notice that the water aint got any bonding at all though said that needs 2 be done but she replied son I'll be dead by then and started laughing.
Reply to missing earth in the Australia area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
