Missing Earth??? | Page 2 | on ElectriciansForums
Discuss Missing Earth??? in the UK Electrical Forum area at ElectriciansForums.net
sl1210
Hi guys,
On a job in a flat today i found all the sockets in the kitchen above worktop have no earth whatsoever. Basically they are new metal backboxes and all they have is 2.5mm singles in plastic conduit running to the new positions. Now I'm guessing the line and neutral are coming from one of the original sockets at low level behind a kitchen cabinet. But that would mean causing a lot of damage to get to. The orignal sockets are earthed from the consumer unit via metal conduit.
What would you guys say is the best way to get the 6 sockets earthed. I was thinking of taking an earth fly lead from the nearest earthed socket in the lounge??? As its a ring, would it need to be 6mm???
What are your thoughts???
Reply to Missing Earth??? in the UK Electrical Forum area at ElectriciansForums.net
In Theory that’s a good argument but if you will be adding or moving switches or sockets or adding lights you’ll more than likely end up needing a...
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
