Mixing HF and non HF lights on a circuit | on ElectriciansForums
Discuss Mixing HF and non HF lights on a circuit in the UK Electrical Forum area at ElectriciansForums.net
Lounge
I don't do it, the manufactures say it can burn the HF's out, what's the physics of what happens if you mix a HF fluorescent light with a standard wound gear on the same final circuit ?.
I like detail..;)
J
I/we do it within our company because we are gradually changing over from wire wound to HF. There could be a science to it but we have looked at the science and cost. If there is a problem with the science at least HF units can shut themselves down. We looked into gradually changing over and when putting out to tender nobody appeared to see this as an issue. I suppose they were only at the initial proposal stage and not the final and technical stage!!!!
Reply to Mixing HF and non HF lights on a circuit in the UK Electrical Forum area at ElectriciansForums.net
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
Along similar lines. I got a call to investigate fault on lighting circuit (which sounded quite simple) and coincidentally I was in the area so...
