MK fuse board modification question | on ElectriciansForums
Discuss MK fuse board modification question in the UK Electrical Forum area at ElectriciansForums.net
P
podcmd
Hi All,
I have just joined the forum to ask the following question and hopefully get a way forward.
So i bought this electric cooker: Zanussi | Cooking | Cookers | ZCV665MX
Then realised there was no electric cooker unit in my kitchen. So it would need a new circuit added to my fuse board.
I have attached pictures of my board. Anyone know where i can get parts to make this work. Extend the bus bar section, add MCB, then do the wiring..
Electrician has quoted ÂŁ350 for a new board and installation of both that and cooker. I have bought the materials myself for the cooker and was just wanting the installation to save some money.
Thanks for all help [ElectriciansForums.net] MK fuse board modification question[ElectriciansForums.net] MK fuse board modification question
not sure if a new breaker can be squeezed in there. as it appears to be an obsolete australian board, the ÂŁ350 quote for a new CU to current standards looks your best option. esp. if the ÂŁ350 includes fitting it the right way up. LOL.
thae end MCB looks to be a bit stuffed as well. a new board ( say a 12 way), would clear that up and give room for future expansion.
Hi,
To be honest , there are ways to extend; but then you would be going away from the manufacturer's design which I certainly wouldn't entertain. As previously mentioned the install of a new board, especially with the crowded MCB's at the RH side is I believe the best option. It has already been mentioned in the post above, and I would agree with that.
Regards.
What makes me laugh or infact not laugh at all actually is the OP has spent a fortune on an oven but won't spend 350 quid to have it working safely, I just give up with the trade at the moment I really do.
The "stupid" thing about this type of post is that if the OP does go ahead and have a new board fitted, plus bonding and a cooker circuit done - all properly not only will they have a nice shiny new cooker but a far safer home too!
Or, I suspect more likely, that he's gone out and bought it, under orders from his dearest, not having a clue what's going to be involved in installing it properly!
Reply to MK fuse board modification question in the UK Electrical Forum area at ElectriciansForums.net
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
