MK fuse board modification question | Page 3 | on ElectriciansForums
Discuss MK fuse board modification question in the UK Electrical Forum area at ElectriciansForums.net
P
podcmd
Hi All,
I have just joined the forum to ask the following question and hopefully get a way forward.
So i bought this electric cooker: Zanussi | Cooking | Cookers | ZCV665MX
Then realised there was no electric cooker unit in my kitchen. So it would need a new circuit added to my fuse board.
I have attached pictures of my board. Anyone know where i can get parts to make this work. Extend the bus bar section, add MCB, then do the wiring..
Electrician has quoted ÂŁ350 for a new board and installation of both that and cooker. I have bought the materials myself for the cooker and was just wanting the installation to save some money.
Thanks for all help [ElectriciansForums.net] MK fuse board modification question[ElectriciansForums.net] MK fuse board modification question
I have seen it many times Daz, a lot of women like gas cookers rather than electric ones and the old cooker outlets get swapped fo a double socket, I have lost count of the amount of times over the years I have seen it happen.
These were actually built that way though.We've got a gas cooker which means my fridge is running from a 6mm T&E.
Do you think this will be up to the job? :ack2: Daz
Hopefully the OP will return and answer the question=is there an electric shower in his home? if not I am certain there will be a twin socket in the kitchen with a 6mm2 cable already in it waiting to be used for his new cooker, come on OP have you got an electric shower?
Reply to MK fuse board modification question in the UK Electrical Forum area at ElectriciansForums.net
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
