Alla Musica
I'm truly sorry to hear what happened to you. That's just unreasonable, given that it's far below the limit and that it's a simple switch rather than electronic...At the time, between 28W and 40W lamps were fitted.
OK, getting plaster dust inside would explain things and is not a manufacturer-related fault.It wasn't a loose wire, so either a dodgy contact or plaster dust had got in. I had a broken faceplate that had got dropped before installation and swapped out the switch insert and no problem since then.
I wouldn't want to judge a manufacturer on a single switch failure anyway, and we don't know if it was plaster. There was obviously dust in the air due to various decorating works and it didn't seem to affect any of the switched sockets or other switches that are in the same room; however, if I did carry out an autopsy, the result wasn't conclusive.OK, getting plaster dust inside would explain things and is not a manufacturer-related fault.
On the other hand, speaking of Logic Plus, I'm having problems with my terminal screws which have worn out upon installation (3 out of 5 gangs failed). Never going for it again.I wouldn't want to judge a manufacturer on a single switch failure anyway, and we don't know if it was plaster. There was obviously dust in the air due to various decorating works and it didn't seem to affect any of the switched sockets or other switches that are in the same room; however, if I did carry out an autopsy, the result wasn't conclusive.
All I am saying is that, statistically, MK Logic Plus hasn't been the most reliable lightswitch in this house because there were 5 installed 15 years ago (if we count a 2G switch as two) and one failed. You could also say that the very old Ashley lightswitches haven't been reliable because there were 4 in use 15 years ago and one has since failed. The sample size is insufficient and there a lot of lightswitches in this house and some get used more than others. I just thought I'd add my sample to the other 5 pages as, combined, the sample size becomes more meaningful.
And so are the Hager Sollysta line, FYI.the Mode and Polar ranges were made in China...
What about Electrium (Crabtree, Marbo[ourn], Volex, and Wylex brands)? Wikipedia still shows one UK factory, whatever that means...And so are the Hager Sollysta line, FYI.
I'll email them - please wait for my next reply. CheersWhat about Electrium (Crabtree, Marbo[ourn], Volex, and Wylex brands)? Wikipedia still shows one UK factory, whatever that means...
Not to worry at all - you're not the only one who suggested that Click accessories were made in the UK!I expect most low priced goods to be manufactured in China, but thought I'd read that Click manufactured accessories in the UK.
Makes total sense. No wonder the Varilight white unfurnished dimmer faceplate (UK-made) were far more expensive, i.e. £7~£8, while that of Click is only £1~£2.I guess they'd be much more expensive if made here.
@nicebutdim Mate - have you ever come across Knightsbridge accessories please, and how do they fare? (I have a discontinued in-line dimmer from them, and just came to realize that they also made wall accessories)
There was one occasion when I was enjoying the possession of my newly purchased Click Mode wall switches - and water sprayed onto them by accident and I was in total panic.It wasn't a loose wire, so either a dodgy contact or plaster dust had got in. I had a broken faceplate that had got dropped before installation and swapped out the switch insert and no problem since then.
@Ric2013 Mate, with the absence of a prompt reply from Electrium, I would assume they're made in China, or elsewhere with cheaper labor cost, given their similar cost to Click Mode.What about Electrium (Crabtree, Marbo[ourn], Volex, and Wylex brands)? Wikipedia still shows one UK factory, whatever that means...
