Mobility scooter and power chair testing | Page 3 | on ElectriciansForums
Discuss Mobility scooter and power chair testing in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
TBH as part of the service contract should they not also be inspecting and testing the chargers?
You would have thought so....
It all just sounds weird.
I would probably issue a Certificate stating that the Low Voltage wiring on the chair/scooter is safe for use, does not represent a fire risk and should be re-tested in 12 months time.
I quite agree, the question is what certificate?
Out of interest, what tests should be carried out to verify that "the chair/scooter is safe for use, does not represent a fire risk"? After all @oracle will be putting his name on this 'cert'.
@oracle : Ask what electrical tests the mobility company do.
My idea, is that the chair/scooter will be ELV, so stating that all low voltage wiring is safe will in fact be meaningless.
I would probably make something up based on a MEIWC.
TBH, if it were me and he made a statement like that I'd politely decline his request and just tell him to contact the agents for the scooters for his bullshyte certificate.
So would I . There is so much ambiguity and buck passing going on here.
As someone who carries out fire risk assessments I both agree and disagree with this H&S fella. Firstly there is nothing you can submit to suggest these scooters are not going to catch fire, walk away as this is an --- covering request which is passing responsibility to you. Secondly if these scooters are placed on or near an escape route they can pose a significant risk. There are instances of combustion where they are left on charge unattended and also arson attack. Most of their component parts are highly combustible and they can rapidly burn out of control. He has a valid point.
Thank you, I was hoping for a response from an H&S assessor like you. I have already tested all the charge leads and I'll include the recommendation for him to clarify electrical safety risks with the mobility company concerned.
Reply to Mobility scooter and power chair testing in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Thanks mate for the advice, this is just what I was looking for. I think I’ll have to put some thought into the domestic route due to the NVQ and...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
