Mode not supportedddddddddd | Page 2 | on ElectriciansForums
Discuss Mode not supportedddddddddd in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
It’s ment to be plug and play system. Both the av and ar shouldn’t of been an issue.
Plug and Prey ..If you don'y get kit from same supplier ..
I have a 15w--15w cable works worst than a
15w-Cable-DVI : DVI-adaptor-15w ..!!!
..but can probably add ...
a bent pin + damaged socket for further inconsistency
(PC Situation)-Now in recycle-
. (Even my Philips Monitor-buggs me). :D
.. Solved last shortage of distant monitor with a lucky visit to a more local "Cash Converters "
Reply to Mode not supportedddddddddd in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Are you testing the setup with the components 'out in the open' and the fault is persisting? Or are the units installed in the fabric of the...
I'd recommend getting a website up and running ASAP. And sign up to google business thingy so your website ends up in Google maps etc. Fill it...
