P
Pyrex
We have hit a snag with PAT testing of some computer monitors in our school (class I). We have a basic battery powered Seamark PrimeTest 50 PAT tester. Earth test passes fine, but then the insulation test gets stuck on "Check Connections", which means the monitor is not providing sufficient load. The monitors do not have a physical power switch, just a button that you can press to turn them on when they have power.
Oddly some of the identical monitors in the same room do not suffer this problem. They pass the insulation resistance test without a problem.
An electrician who was doing some other work for us tested a couple of the problem monitors with his much fancier, mains-powered tester and they passed without issue.
Does anyone have any advice on how to test these? Maybe we just have to buy/borrow a better tester.
