More than one circuit on breaker | on ElectriciansForums
Discuss More than one circuit on breaker in the Australia area at ElectriciansForums.net
R
Richard3009
I have found in my house on the downstairs ring main that three lives are terminated into the 32A circuit breaker, two are for the ring main as you would expect; the third is for a socket below the fuseboard, to all intents and purposes its just a spur and electrically wise its sound.
Just wondered how this stands up with regs having three conductors in the breaker.
yes, would agree with wetstring - it is acceptable to have a spur on the circuit from the consumer unit in this way.
Never done it on sockets, but it is a good way of adding an outside light on a lighting circuit if there are no spare "ways" in the consumer unit.
if i was designing a circuit being fed from an mcb directly to a socket irrespective of what other cables were in the mcb already i would see that circuit as a radial, not a spur.
26a cable and 32a breaker :confused:.
i see where your coming from spurring from existing socket etc etc but not from board.
just my opinion ;)
Reply to More than one circuit on breaker in the Australia area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
BS3871 type 3's have a similar shaped operating curve to BS60898 type C's. Any fault that will meet the disconnection time of 5s (for 63A...
